Thanks again for your help!
Does the prop have a solid hub with the 3 delrin snubber strips? If they are worn, you will get prop rattle at low rpm, and it will smooth out at higher rpm. You can buy new strips from Mercury. If it is not the solid hub, the hub insert might be worn causing the same issue.I recently bought it. I've had other big Mercs & recalled them having the similar characteristics. However, I'd appreciate your help, if anyone has a definitive answer? Thanks
