nlehman76
So I was changing the fuel lines on my motor the other day and noticed that I have some tan goo running down both sides of my engine. Wasnt sure what it was, but sure it was not normal and look like it was coming from under the flywheel area. So I start the research and phone calls.
Well it sounds like the tan stuff is coming from the stator because the stator is getting to hot.
So I get out my service manual and start looking up how to do some stator test.
I tested the wires going to the charging system first (four yellow wires going to regulators). That ohm test came out ok. Then I did the ohm test on the voltage regulators (since I was there). Well this test came back out of tolerance. When checking the diodes in the regulator, I believe that the regulators are only supposed to let current run in one direction. I could not get a short or OL reading on my ohm meter when testing the yellow and red wires which makes me think the regulator is bad and allowing current to flow backwards to the stator and causing the stator to heat up. Thus the tan goo.
Does this sound like I should change the voltage regulators. They are $125 a pop and I have two of them so dont want to change unless really need to.
Thanks for your help!
