I have done some prop research on Merc's website, and I plan on contacting a local dealer.
You probably won't need much more than what you have for props now if any at all. Remember that's a pretty heavy hull and if you plan on spinning 8000+ it's not gonna be a huge prop. I would expect you to run about the same as a 250 3.0litre.
Boston Predictor:
Why not try a speedzone. Just ask Boatman and Wildman, they both have tested many diffrent merc props and the speedzone was the best no question. Great holeshot too.
were do you get heavy the one we have here is real light
Hotdaddy, I did some math and depending on what gear ratio you have, you are going to be in the 20 to 22 inch range for a prop to run top end. For water sports, you may have to run smaller! 8500rpm's with the 1.75 gears comes out to 91.9mph before you subtract for slip with a 20" prop or 96.6 with a 21". Your set up will have an effect on final numbers, but I think that is going to be the range of pitch you need to be in.96.6-10%=86.9. Those same 2 props with the 1.87 gears are 86.1mph and and 90.4 before slip. boatman
i have two friends with pulsars. one has a 95 merc 2.5 225. he runs 75 all day long with a 25P.
the other started with a 3.0 250 merc and would run 77-78 with a 27P. he then sent his motor out to simon for a suposed 345 horse kit. he was running 86.7 with the same 27P tempest before he blew up his stock l/u.
both run 8" setback and jack it to the sky.
good luck
300x's seem to run in the lo to mid 90's
