Will30
That will be a last priority. I've been looking at parts for these old engines and all the other necessary parts for the boat and it adds up quickly. I would eventually like to get to that point but for now I don't need anymore moving parts. I was looking at a midsection of a short shaft merc of this model year at this old marina. It was just the midsection with the transom mount with the power trim parts on it and it looked like I would have to swap quite a few parts.
Its not hard to Change at all . You take the 4 bolts out of the old rams . Pull the rams and put the power rams on the same way . Takes about 30 mins or so .
For your transom you can drill through the glass on the inside with a boring bit and see if the wood is wet . Chances are the transom is shot . I towed my Trimate II home from Cleveland Ohio and the motor didn't bounce or anything . Transom sounded rock solid too . Put the boat in the water ran it for about a half hour . Got it back on the trailer and noticed the motor had busted up the back of the boat pretty good .
