starviper10
The floor was next, a ¾” sheet sealed on the bottom & edges before going in. That was screwed down with 2 sheets of glass between it and the stringer. Then a large sheet went on next overlapping to the hull. I put the knee braces in at the same time with glass between it and the floor & transom. They are made of 2 ¾” pieces put together just like the transom. Those were tabbed into the floor & transom on both sides as well.
Just to be a dick, how much difference would 3/8 of an inch make, you must really be an engineer, 5 page blueprint???
I made something similar to that for my first MX-15 out of scraps at work, mounted it up on the transom and went to drill the mounting holes and a regular drill wouldn't touch it, turns out it was inconel for making airplane motor parts, had to get solid carbide drills from work to make any kind of hole in it, tough stuff
