jammasterj787
red i hope you use a thick bead of high temp rtv when you stack head gaskets !!!!!!!
Yes it is a tall deck 632,yes, has to be a tall deck to do a 632, if it has 70 psi OP and not oiling up the pushrods, something is wrong with the main or cam bearings or their installation...also be cautous of the rear cam journal and the rear cam bearing....don't think the oil cooler is your problem...Rob
im going to be taking off the tunnel ram set up,i think it will hurt some power but not much,im putting a brodex intake on it with a 1200cfm carb from pro systems.and i just found out that the oil cooler wasnt the whole problem,it has a bad lifter on #7 causing a blockage to the whole left bank of the motor..i just ordered a new setof lifters from comp today,im just glad to have it figured out,and very glad i didnt mess anything up as of yet.
I have a brovo 1 ,with the x gears in it...its a 1.5 gear ratio,its a mater of time i know,but i change the drive oil every 20 hours,and in the bay i try not to zing it to much in big chop...i have lathum steeringhey check 632 what drive/gear ratio you running to get in the 80s like that? is your steering stock setup?
its a 4 blade that has had alot of work done on it by B Blades in N.Y.so your getting 89mph with a 1.5 bravo and a 27p spinelli ? is that gps speed? and is that a 3 or 4 blade prop cuz i think im doing something way wrong!!!!!
IT STARTED LIFE AS A 502whats done with the 540 you have? u said its 19 years old? i didnt know they made 540s that old. did it come with the boat from the factory?
Damn I gotta try to see if I can get my prop to only have 6% slip on a 251 thats nuts. I dont know how that prop shop did it !!!
Put the money ,and will see.........o yeah by the way check632 your not gonna blow my boat off of any river unless you have a really good paddle !!!!! because my boat runs!!!! killer
Not you again,you are very anoying,ill run that yellow motor chit box this week end,for no less than a grand,so waz upthe pics will be here sone enough,as sone as i get my camera from my wife,and beleave me i seen pics of your peace,its a nice one,you better get your prop chit straight first,because i cruise almost faster ,than you trimed and wide open..., because you are not very fast to be talking trash,you and your 11.8 cam2 drag racing motor....until you post pics this thread is B.S. now you wanna race me with a blown motor good luck to ya buddy keep dreaming when your driving your bayliner.
THANK GODhaha your one funny towel head aladdin make sure you dont get that carpet wet when your flying around the river.
Im done with this thread lol
