I finally have gotten the time to get back on this. I can say, it you are doing something like this and dont have a multi/oscillating tool.... BUY ONE and get a carbide blade for it. Cuts through the fiberglass like butter and gets in the tight areas around the transom with ease. For the long cuts on the floor I still used the circ saw...
Here is where I am at now. Everything is cut out and I prepping the fiberglass core to be prepped for the new stringers to get glassed in.
- Do I need to grind/sand all of the fiberglass until it is smooth? You can see in the pictures that it looks like a basket weave. In the second picture is a place where I did sand it smooth, but I feel like I am getting to close to the core.
- Do I need to wipe down the whole inside to get rid of all of the white stuff? If so, what should I use? Seems like when I hit it with a wet rag, it goes away and comes right back after it drys.
Thanks.... hoping to pick the pace back up and get this thing finished by the middle of April. Got the new engine now and I am JONESING to get back out there.
Thanks for your help!
Looking good!!! The white stuff is bondo the factory used to fill voids. you'll need to grind that off/smooth also the black needs to be removed as well. You want a nice clean area for the mat and resin to adhere to. You can use acetone to wipe the inside hull down.
