I was out last weekend doing some prelim testing with a new prop and jackplate when the passenger seat gave way with my 240lb buddy in it. The front screws had pulled up allowing the pedestal to rock back some. When I got home, I checked it out and ended up getting out the hole saw and cutting out about a 2 1/2 sample directly in the center of the pedestal mount. I now have a pile of black wet mulch . I could actually sqeeze water out of it with my fingers. There is one solid bolt hole left. Oddly enough, this boat appeared to be in great shape with the original interior in fairly great shape as well. The transom and rear bracing look/feel/sound solid and dry but now Im starting to wonder. However, I did stick a screwdriver in the engine mounting holes on the transom and scraped around and it all seemed pretty solid. Although, the floor feels solid as well. I also noticed black wood underneath the ski pylon hole. If I want to secure down the seat and delay a total overhaul, I would have to use the 1 solid bolt hole left and rotate the pedestal utilizing this in a new location and drill 5 new holes and put in something like a moly bolt. Provided I can get the seat somewhat solidly bolted down (which Im not so sure I can) is this something that I can put off until next winter....I've only had the boat out 3 times since I bought it and would like to use it this summer if possible but dont want to chance it. Also, if the transom needs replaced,is it possible to do so without separating the deck from the hull? Also, how much total could I expect to spend on a rebuild this including, a syntetic material like mantex etc, resin, glass, new interior, etc?? Thanks in advance
