ontherocks83
Earlier this spring I went to start my 89 Strobe 201 with a 5.7L and because the PO ran it in salt water without ever flushing it, the block finally rotted out and it started pissing water right out of the port side of the block.
Needless to say my season was ruined. I am going to pull the engine and do a whole host of fiberglass work while it is out.
Does anyone have suggestions on where the best place is to get a reman long block? Right now I am considering a couple of options.
(Option 1) Get just a long block, swap over all of the tin, and be up and running for as little expense as possible.
(Option 2) Get a bare block and a stroker kit and build the engine myself, but would like to know how much more would something like that be as compared to just a long block. (also would I need a new carb or would the original suffice?)
(Options 3) Save for a little longer and go full new engine or maybe even big block. (this is the least likely but still on the table, I would just be out for at least an additional season)
Suggestions would be appreciated
