Blkcorvair
So I finally mounted my new to me motor.
2002 merc 250 efi 3.0 20” shaft
On my 2001 pulsare 2100
I did a little testing today and I’m getting the oil sensor beep. But the tank is filling and she’s blowing blue smoke so I’ll figure that out.
Bigger problem is as soon as I get the boat on plane, the prop blows out. Running a new trophy 4 blade 25p. Motor is mounted in the same position as the old motor. The only way I could get it to stick was bury the jack plate all the way down. Don’t like that cause it’s so low the hydraulic steering will hit the transom if I trim the motor up a little too much.
Took it for a few short runs like that and I cant believe how fast this thing jumps out and gets up to 55+.
Any ideas why this prop keeps blowing out or what it could be? Almost feels like the shaft on the motor is too short like I can’t get it low enough but I measure my old 200efi and they are both 20”.
Could it simply be that the holes on the prop need to be plugged? For now I left the 4 PVS plugs the stock big hole that came with it. I have some others around here that I can try but didn’t think those would make the prop blow out. My 200 had 4 large hole PVS plugs in my 23P trophy and had no problems like this????
