Howdy Yall,
This is my first post. I have an MX 15' checkmate with a 115 merc. I have been a boater for many years, but have never had a Merc. or a speed boat before. I need some help with setup, and prop selection. I would like to be able to ski and still have a reasonable top speed(i know you can't have your cake and eat it too). Can anyone recommend a good manual and or online resource for an inline 6 merc? I rebuilt the carbs with new floats needles & seats, and gaskets. I think that I need to sync the carbs. I do not know how to set the timing to 21 degrees. There is a loss of power/speed in the last 1/2 inch of throttle. The boat weighs around 550# dry. The tach seems to come and go, so I'm not sure that it is correct. The prop that came on the boat is a 13*19 aluminum 3 blade. Running at wot it's showing 42-4300 rpm at +/-45 mph indicated. Is there a book or online resource that would help me better understand performance setups? I do have a pressure gauge, but it is old. It works on the upper range, 10-15 psi, but not 0-10. Sits on 10. The setup is the problem in my mind. The cavitation plate is almost flush with the bottom of the hull. The motor clamp is about 1" above the transom using a wrap around spacer. At speed, I get a little chine walk. The bushing on the motor side of the steering arm has some play, so I'll be replacing that first. How tight or loose should the motor be in the mounts? I do not know what the "right" set up is, or how to do it.
Any help would be appreciated.
Thanks!
Thanks!
