Merc Blackmax 200 2.4
JUPITER PULSARE
1986 Mercury Blackmax 200 2.4. This is the original motor that came on my Talon. I just did a compression test: #1/145lbs, #2/140lbs, #3/150lbs, #4/145lbs, #5/145lbs, #6/140lbs. Motor would make a great drop on powerhead!! It does need some minor detail..It has one bad trim solonoid, needs new plugs, could use some minor rewiring (to make it right), carb cleaning (from sitting for 3 years). The lower unit has a nosecone with 5 intakes and a torque tab welded on and fresh gear oil. I just had the welding cleaned up (therefore the lack of paint on the skeg in the picture). I've run the lower unit up to 80mph and it shifts and runs great!! It only needs a new water pump and housing. I would like to get $2500. for the package.
I'll separate the package. $1200.oo for the complete powerhead inc. cover and midsection, $800.oo for the lower unit. Need to clean up my garage floor!!
Not a bad price someone will need it A friend of mine just bought a brigeport 2.4 online for $2600 -1995 efi with all the bells and whistles
2.4 or 2.5 block
I'm in need of a 2.4 or 2.5 200hp Black Max block . ( help ! ) or a complete power head. Reed
