Save yourself some money and use polyester,cloth.woven/roven and some csm.the money you save you can use for when you do deck, stringers ect. then use epoxy on that phase of project.
Read this thread on epoxy resin: http://checkmate-boats.com/forums/showthread.php?t=23210&highlight=epoxy+resin
Just checked out the US Composites Site.Man that stuff is way cheaper than West Sys.
B.O.A.T Bail out another thousandI think west marine was the first to coin the phase break out another thousand for B.O.A.T. they are high but will price match from time to time.
You can gelcoat over epoxy if you use a primer. I think there's a thread somewhere on the forum. I'll see if I can find it. I went back and looked at the damaged area. Because it's small I would use polyester to repair the damage then gelcoat. That way you won't have any problems.
Edit: This is from Badbk's resto thread http://boatprojects.blogspot.com/2012/01/gelcoat-polyester-over-epoxy-synopsis.html#
and the link to his resto: http://checkmate-boats.com/forums/showthread.php?t=23179
Pretty sure there will be lots of questions before this is done.Thanks again.Just got to get to it.You will do ok. prep it and slowly build it up, shape it.maybe some more glass, finish sand it,put some gelcoat to it.preparation is key! And if there is a question always ask.you can mix cabosil into gelcoat to make a filler.Dont use bondo below the waterline... it will fall out.
