redstrat
Nice work. 3 out of 4 crazy boat restoration guys say that marine ply is unnecessary. Good quality AB exterior (good one side) ply is just as good. You'll be covering it with epoxy to keep moisture out. I dealt with unwanted holes by feathering the hole larger on the inside with a grinder, put masking tape across the outside, cut up small pieces of mat for the inside of the hole and larger for feathering out, laid it up with epoxy/cab mix, before it fully cured I pulled the tape off. After it cured I ground a bit on the inside before clamping in the transom. You'll be cutting a lot of that damage away if you're still planning on removing the splash well. What shaft length motor are you using? I think we'er all envious of your warm garage.
