Stevenlockamy
My guess is the 28 prop will be to much. I'm running same boat but has open bow. Running bobs nose cone with 8in set back. And a 24p big ear that I cupped and worked myself. With a custom drag plate I built under jack plate to stream line water and prop shaft 1.5in above pad. I run 73gps at 5,600 rpm. With only the last foot of boat in water. With a 150merc. That's had work and heads are 24cc and 135psi. Also 93 octane with 110octane mix. But it's taken me building my own motor and 1yr of fine tuning. !! Also took all wood out of boat. And replaced with aircraft honeycomb. So lost a round 100lbs. Maybe this set up will help you? Best of luck my friend.
