I see some using a expoxy to bond new transoms to the skin but it appears the PL premium construction product is able to bond fiberglass to whatever and is waterproff once cured. Given it can also be used as a filler/bonding adhesive would I really need to fill in low spots on the skin before setting the transom? In other words, is the stuff good enough to just trowel on and be a all in one filler/ bonding agent?
Also thinking of just using it to bond the the transom sheets together and then encapsulating the whole new transom in fiberglass, edges and all. As long as all holes are properly sealed why mess with mat and resin between sheets?
Thoughts?
Thoughts?
