I'll probably have questions as I start the process of rewiring the Enforcer. My first question is the navigation lights. The black wire on the navigation lights was tied into the battery by the PO? I'm not sure if this is correct since the switch on console is wired to a fuse box/ block underneath the dash. I'm guessing that the lights shorted out so it was wired different. Here's some pictures of the cluster I pulled out from underneath the dash and gunnells and some others as well.
The cluster fcuk:
One of the batteries, have'nt added the other yet
The oil tank
The cluster fcuk:
The oil tank
I went back out to look at the nav lights, looks like the PO cut the ground to tie another in right underneath the dash/console. That wire was also cut and tied. I'm still trying to figure out why the ground was cut on the nav lights near the stern then a ground wire was added to the battery. Damnest thing I've ever seen. Oh also forgot the yellow wire for the gas sending unit. WTF!!!!!!
It does have all the original switches in it and may be worth a lot of money some day
