Ramifications
1996 Aquasport 225 Explorer with a 1996 Johnson ocean runner 200 HP sitting on a 2000 Venture Trailer - $9,500
This is a walkaround cuddy cabin style boat with a solid ride and lots of deck space for her size. She comes equipped with all of the necessities for a nice day on the water with the family and friends. She is a great cruiser or fishing boat and has the ability for an occasional overnighter. Everything on the boat and trailer work as it should. No hidden issues - Boat is currently in the water and available for test ride for serious buyers.
She does have a few blemishes here and there, but overall good shape for an 19 year old boat. She is structurally sound and turnkey ready!
Performance:
Cruising RPM is 4000-4400 and will put you between 25-30 MPH
Top end RPM is 5500-5600 and will make about 35-38 MPH
Cruising fuel burn is about 12-15 GPH or 2 MPG
Wide open throttle is about 20 GPH
The boat:
1996 Aquasport Explorer 225
LOA -- 24'
Beam -- 8' -- 6"
Draft -- 1' -- 6"
Deadrise -- 19 degrees
Fuel -- 102 gallons
Dry Weight -- 4100 lbs
The boat comes with:
Bennett Hydraulic trim tabs
LED cockpit and helm lighting
Bimini top with full curtain enclosure
Uniden VHF radio
Lawrence GPS/Chartplotter/fish finder
Raymarine A98 touch screen GPS/Chartplotter/fish finder
Snap on Bow cushion and rear seat cushions
Two newer batteries -- installed Sept of 2013
30 gal live bait well
Salt water washdown
Large in floor fish box with new macerator pump
Under gunwale rod storage
Transom door and swim ladder
Anchor with 10' chain and 150' line
Stern light
All cuddy cabin cushions and porti-potty
Built-in cooler in cuddy cabin
Rod storage in Cuddy cabin
Forward and stern automatic/manual bilge pumps
Third backup 1800 GPH automatic/manual bilge pump
New fuel tank sending unit
The Engine:
1996 Johnson Ocean Runner - not a Ficht!!
There are no known issues with the engine, trim/tilt or lower unit. All have been working great this season. The engine just had a tune-up with new plugs, fuel filter, carbs cleaned and lower unit oil. The water pump impeller is in its second season. Unknown amount of hours on the engine
The Trailer:
2000 Venture dual axle (torsion axles) trailer roller trailer
New hydraulic surge brakes
New brake drums
New bearings all the way around
New hydraulic brake lines
New Titan model 60 tongue
New winch cable
All new parts were purchased and installed in June of 2014
The trailer does need new fenders as the old plastic ones are falling apart. The lights all work and tires have good tread left on them.
Price $9,500
Call Spencer (856) 207-7174
Currently in the water in Delran, NJ - on the Delaware River
Performance:
The boat:
LOA -- 24'
Beam -- 8' -- 6"
Draft -- 1' -- 6"
Fuel -- 102 gallons
Uniden VHF radio
Salt water washdown
Stern light
The Engine:
The Trailer:
New brake drums
New winch cable
Price $9,500
