Starflight Splashwell delete
I'd like to delete the splashwell on my Starliner if I ever do a transom on it. I think I'd just bring it up to the top of where the upper motor bolts are now and put about 12 inches of set back on it. I think a full on bracket would be too much and make it porpoise a lot.
Do some searching on it cause I know somebody here did what atc250r is talking about. Made it more like a Pulsare splashwell. There was still a well, just no lip.
I don't think I'd go that route although it'd be nice to put a small, upholstered sun deck back there. I like the Pulsare set up and it won't require such a huge set back for motor clearance.
Removing the splash well will work fine so long as you use a set back of about 10" to 12" otherwise there will not be enough room for the top of the motor and cables when you raise/tilt up. If you don't plan on setting the motor back that far you will have to leave some splash well for motor clearance.
Here is a couple of pics of my MX-16 with 6" set back
picture.php
picture.php
picture.php
Nice little pice of work there redstrat! BadBK delete the lip on his Starflite that he started...I think there were pics in that thread.
