FluidGrooves
Hi All, I have a 87 Starflite with a 225hp evinrude. I am getting ready to put her on the water in a few days and I had some questions. First, Engine height:Where do these things run best? I have a 27 pitch renegade with 8&1/2 inches of setback and was running the cav plate dead even with the flat panel on the bottom of the hull, which is several inches above the bottom of the v. I was having slip issues last year with both hole shot as well as top end (was running 56-58 on speedo while spinning 5500 rpms). Should I go higher, or lower? Also, Where should I be as far as water pressure. My gauge was reading 10-15 psi between the midrange and 5500 rpm. Any help is greatly appreciated. Thanks, Jim.
