Eaglenva, What motor will you be using? Have you considered modifying the hull like adding a pad?
The repairs for those should start from the inside if the boat, just filling those will not make that a safe repair they are well through the hull there is zero strength in those spots right now and there will be zero there if you just fill them. You need to route out the strake from inside and do a proper layup inside the hull then you can refill the inside and fair in the outside then put whatever topcoat you plan on using.Remember this is not your 35mph go to the marina boat it will take some beating when you ger her finished.
The structure is in the core, not in the strake!!!
