Will30
No not yet. Maybe you could help me with that if its not hard. I'm keeping it in my garage but i'm not sure if it gets too cold in there.![]()
All you have to do with the inline six is put some startron in the fuel tank. Run motor for about 10 mins to make sure it gets to the carbs. Then spray a whole can of storage seal (fogging oil)thru all 3 of the carbs with the engine running about 1500 rpm . I use two cans one on the top carb and spray the middle and bottom up and down with the second . As the cans are almost empty disconnect the fuel line and continue fogging the carb till the motor stalls from no fuel. Remove the plugs and spray whats left of the fogging oil into the cylinders. Replace the plugs and just bump the motor over to move the oil around in the cylinders . Dont start it . Then change the gear lube . And leave the motor in the trimed down postion for storage . Thats all you have to do .
looking good!
