knarloid
The chance of getting liability on a grossly overpowered boat are slim to none. Until that changes I'll just drive accordingly when I have passengers.
Valid point.
how did it run? Was it a rock out of the hole?
A 15P prop sounds rediculously low even with 1.62's.
I would have guessed low to mid 20's.
Is that a 2.5L or 3.0L? How much does that girl (the boat) weigh?
HD
Are you sure its running right? You should be able to turn ANY prop you want on that setup.
Is it dogging out or slipping on takeoff?
I run a 25 4 blade with a full boat and mine still weighs a good 600-700# more than yours.
What's your gear ratio? 1.75 ?
5500R's at 45mph, yep that will "snap the line tight" LOL.
Good luck with the fat chicks!
HD
