Ok pulled the trigger Kunkal Marine installing and rigging my Stiletto with a pro charger. Cant wait for spring!
Currently boat runs 69.9 MPH on GPS running 25 Mirage, 4900 RPM (Bravo 1 1.5). Started at 66.6 MPH with 24 Bravo 1 5150 RPM.
Very Interesting, What exhaust are you running or going to run. I run a 2000 24 ZT with the same mota except the previous owner was nice enough to install a set CMI E-top headers. I run 72 mph with a 25 mirage plus 4700/4800.
Would you mind if I hit you up for the hard numbers's$$$$ sometime Merc245
Based from my prop testing a change to a 25P Mirage will get you an additional 200-300 RPM's with no other change. No problem on the $$$, his estimate was $8,300, will let you know when we are done.
Stock Merc Manifolds but asked Jason if changing to headers would help. Jason stated not necessary but would help. Looks like from your results 2-3 MPH. Not sure if Jason will be changing the head gaskets or not but I don't think so. Think the plan is to keep the boost down around 3 PSI to keep her reliable. I will continue to post as we go.
Are they Mirage or Mirage Plus?
Good Question, Finally ditched the flip phone myself.![]()
Let me know if you want to try one of these props
