Combat Rock
I have a 85 evinrude 140hp v-4 looper
and i had a very irratating weekend
I had it out for a while and it was running perfectly
(well sort of) and I turn it off and float for a bit
and when i go to turn it back on after about 10-20 minutes
later and IT would NoT START
I kept tryin it thinking it flooded out or something
and my battery got lower and lower
to the point where it wouldnt even turn over
I get towed in and thinking i just had a low battery (wich is almost new)
I charge it up and try it again in the morning
and it did the same thing would Not start
but the battery was all charged up, so i get towed in again
it has a few quirks,
the tach bounces around alot
sometimes it wont work at all, if i put it in nuetral it will come back on again
and then im good for a while
and if it starts acting up under power usualy around 4000 rpm
ill play with the trim or accs. and it will come back on again
the other thing is when i really open her up
sometimes it will cut out briefly for a split second then come back on again
it seems to do the more and more frequently
i thought it was a bad fuel filter so i changed it.
but that did not fix it.
so
it sometimes doesnt restart after being run for a while
it fouls out at low rpm
the tach is acting wacky (newer gauge)
it doesnt seem to recharge correctly
and it cuts out at high rpm.
i think its all related, my money is on something electronic
i know a bad rectifier can cause the tach problem does it have anything
to do with the other stuff????
any help Much appreciated.
!I kept tryin it thinking it flooded out or something
so
