175checkmate,
Are you saying to put a couple layers of glass next to the skin; then clamp the rebuilt transom to the wet glass?
Yep, thats what I was saying. I filled in all the low spots and ground off the high spots on the skin. Then wetted out 2 layers of glass then clamped the wood to the skin. I used a bit less hardener in the resin to increase the working time. Once it was set in place, ( I screwed mine instead of using clamps) I was able to remove allot of the excess that squeezed out.
Once the first piece of transom was in place and set, I put a layer of glass on the new wood and ran it up the side of the boat about 10". I then sanded it flat, then repeated the process for the remaining 2 pieces. Once the finial piece of the transom was in place i covered it with 3 layers of glass, each running up the side of the hull 12". Overkill, oh yea.
.......OH, the transom is two sheets of 3/4 and a sheet of 1/2, not sure if Im gonna have to trim for the splashwell or not. I figured since I wasnt using marine ply I might as well beef it up a bit. Still deciding if I am going to do just knees or knees and a thorp type crosspiece. Plan is to bond 3/4 and 1/2 plywoood for the knees........
