Even More CL Finds!
86 Diplomat w- 135 Merc for $9500.....
http://minneapolis.craigslist.org/ank/boa/4842939821.html
82 Eluder w- 200 Evinrude for $1800.
http://sarasota.craigslist.org/boa/4844111073.html
96 218 Persuader w- 350 Mag for 11.9k.
http://atlanta.craigslist.org/nat/boa/4843970437.html
251 Convincor w- 454 (500) for $6800.
http://myrtlebeach.craigslist.org/boa/4844621113.html
84 Eluder IO w- V8 for $5500.
http://kalamazoo.craigslist.org/boa/4844789894.html
93 Pulse 211 w- 115 Merc for $6500.
http://ocala.craigslist.org/boa/4843975759.html
84 Diplomat w- 115 Merc for $3750.
http://saginaw.craigslist.org/boa/4819919716.html
Enchanter w- 175 Evinrude for $2500.
http://southjersey.craigslist.org/boa/4848842658.html
90 186 Pulse w- no engine for 3K.
http://northmiss.craigslist.org/boa/4849355203.html
88 Enchanter w- sbc for $3200. With a little elbow grease, this could be a very sharp boat!
http://detroit.craigslist.org/okl/boa/4847442394.html
89 Vision for $5500.
http://sfbay.craigslist.org/sby/boa/4846927563.html
95 Playmate Jet w- 175 Merc for $6500.
http://seattle.craigslist.org/oly/boa/4848099827.html
72 CM for $1500.
http://charlotte.craigslist.org/boa/4846477658.html
74 CM w- 115 Merc for $2500.
http://knoxville.craigslist.org/boa/4850422424.html
84 Enchanter w- 200 Merc for $3200.
http://myrtlebeach.craigslist.org/bod/4847531291.html
90 225 Johnson for $3500. Instigator's motor.
http://cincinnati.craigslist.org/boa/4848494460.html
16' CM w- 115 Merc for $500.
http://longisland.craigslist.org/boa/4849615969.html
89 251 GTX w- 454 for 15K.
http://maine.craigslist.org/boa/4849546280.html
  • Like
Reactions: JW
[QUOTE
99 270 Convincor w- blown 502. [url]http://tulsa.craigslist.org/boa/4815198443.html
[/QUOTE]
Here is what the surveyor said about this gem.
He said someone was willing to drive 14 hours from Michigan to buy it,
It sounds like there will be a surprise waiting for them. Should have pics of these descriptions soon .
374 Decals ghost
382 soot around port outlet and trim tab, rich bank
383 drive shower good, single ram steering
386 fractured nut??
Note serial – recalled housing due to steering obstruction inside
387 propeller improperly ground upon , poor shape of blades
394 strap indicates exhaust bellows renewed
397 missing anode on MerCathode
406 port exh, excessive heat and muffler punched out. No flapper to prevent reversion of water into engine
407 compare exhaust temperature and soot, not hole in side of exhaust. Punched through from inside boat.
410 gel coat dmg
412 close prox of ladder to propeller – hazard
414 ladder nuts not secured properly to bolt. Not engaged
415 stress cracks ladder platform
418 incorrect enginecompartment ventilation – restrictred. Starving engine, blower
428 compression damage rub rail
434 gel coat dmg port side bow, large void area behind gel coat. Egg shell only.
453 large gel coat damage hull bottom.
469 one of several air voids in laminate
474 engine compartment, automotive components - violation of law/boat explosion hazard.
477 improper battery installation agm with lead acid charge rate., unprotected terminals
478 improper ventilation ducting
481 illegal fuel pump, improper fuel hose,
491 leaking fuel from carburetors – active, horrendous fuel line connections. Stainless, brass and aluminum galvanically incompatible in this arrangement
502 repairs to shelf
503 repairs to shelf over port side stringer??
506 illegal exhaust installation. Splices and no double clamping, rust of manifold
508 oil in bilge – law violation OPA
508 bilge pump heard, but pickups covered in oil and likely mechanically inoperative.
515 fractured sea pump inlet (sucking air) would not pump water at start up of engines
524 2x6 lumber side boards, really ugly
Snap in carpet at end of useful life
526 note water line under battery switch??
529 Speedometer
532 trim tab indicator inop
536 boost not installed
539 Fyre Watch inoperative
559 cabin sill unusually gapped, suggest movement of cockpit sole
568 excessive tension on fuel fill hose top
569 fuel fill hose condition failing
570 fuel fill hose clamps rusted, improper grade and hazard for leaking fuel into bilge.
576 oversize fuses on bar
622 condition of fenders, likely source of 10 foot gouge in hull bottom
374 Decals ghost
386 fractured nut??
410 gel coat dmg
529 Speedometer
Seems he knows there is a problem. The posting has been removed..[/QUOTE]
95 235 Persuader w- 454 for 13k.
http://sacramento.craigslist.org/boa/4853233936.html
89 Starlet/Fire w- 350 Mag for 7k.
http://grandrapids.craigslist.org/boa/4852147551.html
91 283 Convincor w- dual 454s for 19.5k.
http://nh.craigslist.org/boa/4853424832.html
87 Enchanter w- 5.7L for $9995.
http://phoenix.craigslist.org/nph/boa/4853215592.html
http://stlouis.craigslist.org/boa/4853074006.html
96 2100 Pulsare w- 200 Merc for $6500.
http://pensacola.craigslist.org/boa/4853502912.html
Paradise F-13 (Playmate) w- 50 Merc for 18k.
http://easternshore.craigslist.org/boa/4852364298.html
87 CM project w- 200 Merc for $750.
http://savannah.craigslist.org/boa/4853463080.html
  • Like
Reactions: JW
SH, here are some pics of the 33'!
I was in Amsterdam last week for a short stay. Wish we could have hooked up.
Cheers-
Cheers-
We have to do that! Really looking forward to that! Jjg is also a regular overhere, had fun at the boating meeting of the dutch forums. It was a bit cold but really fun.
Let me know when you are in town!
Where did you post the link with pictures?
Starflite w- 200 Merc for $4500.
http://seattle.craigslist.org/see/boa/4866371234.html
88 Starflite w- Yamaha for $3800.
http://tampa.craigslist.org/pnl/boa/4865641276.html
92 Starflight for $3800.
http://detroit.craigslist.org/mcb/boa/4866219128.html
89 Starflite w- 150 Johnson for $5600.
http://wilmington.craigslist.org/boa/4864415335.html
91 Pacifica w- SBC for $4500
http://hudsonvalley.craigslist.org/boa/4865411082.html
85 Exciter w- V6 Mercruiser for $9995.
http://tampa.craigslist.org/pnl/boa/4866174290.html
18' CM I/O for $1800.
http://nh.craigslist.org/boa/4862161619.html
78 Trimate w- 140 Johnson for $1900.
http://quadcities.craigslist.org/boa/4866497486.html
012 Pulsare 2000BRX w- 150 Merc for 27k.
http://chicago.craigslist.org/nch/boa/4863942119.html
87 Predictor w- 115 Merc for 4k. Nice little boat!
http://detroit.craigslist.org/okl/boa/4866580197.html
