I came up with a moller FT3305 keel tank 21.75 wide 59.5 long 8" center and 7" sidesI had a guy that does welding for a living look at my tank, it wasn't bad enough to replace it. I guess for a piece of mind I shouldv'e replaced it.
Mk hammer that's the best price for a tank I've seen so far. The problem is that's it's too tall. The dimensions are 5" on the side 22" wide and 60" long, it's a 50 gallon tank. The tank looks like this:http://www.overtons.com/modperl/pro...Deck-Fuel-Tanks&aID=601R2&merchID=1009&r=view
I just checked the height on the gas tank the max we can go is 10" from the bottom for the floor to cover it.
but it's 33 gal. $390.00
Also a moller FT3308 would fit but still 33 gal.
Are you sure your tank is 50 gal the reason I ask is the dimensions are not so different.
And one other made by Inca 60-1/4 L. 22-1/4W 8.75 cen. 5-7/8 sides 40 gal
MKHammer
Yes it's fifty gallon tank, right on the tag. I'll get a picture for you later. I'm at work right now.
This is all That's out there I checked with 3- different manufactures. The 50 gal tanks are 24" wide. I suppose you will have to go back to aluminum to have 50 gal.
MKHammer
I would not think you need expansion room for the tank because its vented to the atmosphere.Damn I forgot to take a pciture of the tag. MK thanks for looking, I do know that the stringers are 24" inside to inside. But don't you have to allow for expansion. My guess would be to adjust the stringers in that area to accommodate the newer tanks.
Robbie,
found the book I wrote measurements in; double checked the numbers by remeasuring my fuel tank.
gallons 50
Length 62"
Width 24 3/8"
OA height 7 3/4"
Side height 5"
Bottom width 6"
Looks like our tanks are a little different....... interesting?
I'll be looking at a couple of fabricators here locally and see what a custom tank will cost me. I still havn't contacted CM to see what current costs are on a new tank. I'll need to be sure of the dimensions before I set the stringers. That would really blow, to glass my new stringers in, only to find my "new" tank from the CM factory had different dimensions.![]()
MKHammer
So does that mean your going to stop bench racing and have another entry into your blogI'll be at the storage facility where my boat is stored sometime tomorrow; .
So does that mean your going to stop bench racing and have another entry into your blog![]()
Robbie,
gallons 50
Length 62"
Width 24 3/8"
OA height 7 3/4"
Side height 5"
Bottom width 6"
I wrote the number down from your website; who do I ask for? I need to explore a few options here locally but I may be able to work with a plastic tank. Height may be my biggest problem. I'll be at the storage facility where my boat is stored sometime tomorrow; I'll get a measurement from the top of my stringers to the hull and see what I have to work with.
I just double checked the width dimension on the tank, 24 3/8" wide and from the bottom to the top is 9". The height from the bottom of boat/bildge to underneath the floor is 10 1/2". So technically the one from overtons will work :
//www.overtons.com/modperl/product/details.cgi?i=30458&pdesc=Moeller_Belly_Tank_52_gal_24W_60L_10D&cname=Below-Deck-Fuel-Tanks&aID=601R2&merchID=1009&r=view
Would you like me to beat this price on the moeller 30458 ?
My tank is already under the floor sealed in, but I'm guessing OH would like that. We both have the same boat so it should fit.![]()
