keith4216
Its drying white up after the 1200 sanding.
Do i have to remove the white sanding stuff before i start with the 3M stuff?
I always wash it down after sanding and again after compounding.
Going from 800 to 2000 was a big jump. I would have done 12-15 in between. I have found seeing some color is normal when doing the sanding. I'd go back over the deck again. I just did one worse and it came out pretty nice. Oxidation is like rust if its not all gone it will come back. You can plan on it needing to be buffed on every spring. It will be less work each time but will need to be done to keep that shine. Nice results you got and I understand the first timers fear of sanding but go at it a little more where you can still see the haze.
and the trick to it lasting is a good wax and the least sun as possibale.
Some pics,
http://checkmate-boats.com/forums/showthread.php?t=29188
Some pics,
A mooring cover would be well worth the investment for you.
You may already do this but try one of the many UV protection spray on waxes.
Your cover can be cheaply modified to accept the mooring whips. They do it all the time.when the boat is moored at my dock it is tied to the dock with mooring whips that get in the way of a cover.
My question is can either be put on over the recent application of 3M Finesse IT-II Marine Glaze?
Anybody know any of the miracle waxes/protectants that actually work better than good wax?
We get ship shape TV down here and he's always pitching something that he swears by. Problem is it only shows "just after buffed" finish that would have looked good w/water on it.
Yrs back I had a really nice, multi dark/colored Stratos cuddy that I did the whole sand/buff/polish to and it looked like new when new.
I remember having a beer on it , 1st time out on a hot summer day and you could see EVERY water spot become permanent mark once the sun dried it.
I finally gave up.
The Starliner I just bought, has some minor fading too so this all hits home for me.
i even wondered about re-clearing it. Any of you paint/body guys know if any of the clear coats has much UV protection in it??
I had a race boat cleared yrs ago and the guy screwed up and used the wrong clear coat and it was as bad as nothing at all for protection!
Your cover is the best insurance against fading.
There is this stuff that west coast boys are using called Hot Sauce (boat bling) that seems to work well for water spots. Also, I have used a product called leverage. It's basically a spray wax, but ever since I started using it...I have had no issue with water spots. It takes about 15 minutes to spray wax the Enchanter with the stuff and I usually do it 2-3 times a season. With a black hull and deck, I have been really impressed with the it.
