timapexcomputer
Okay checked every connection at that bus bar. Nothing looked questionable but I cleaned everything. No change. Should I pull the flywheel to inspect the timer thing?
Well you could test it with a Peak reading volt meter, that would tell you exactly what is wrong, otherwise you need a timerbase or a pack, call me if you want 847 356 3245
__________________
bills number and he probally has the part you may need
Yes he is probally closed..being sunday and allCall but no answer. Will try again another time. It's Bill I am calling?
You need to make sure you are not chasing a ghost. Sometimes a timing light will stop flashing when running on a 2 stroke and lead you to believe you have no spark. You need to double check you are on the right track. Does it stop flashing exactly when the motor starts running poorly?
When it starts missing, run the motor to 1500 and pull the plug wire in question, if the rpm stays the same then you can be positive you have found the right cylinder. I would test all 4 that way. A working cylinder will cause the rpm to drop when disconnected. You just want to make sure you are not chasing an ignition problem when it might be fuel. Only takes a minute to verify. The reason I bring it up is that none of your plugs look wet which one might if you were losing spark, and you have done most of the usual suspects on the ignition side. Many times I have chased an ignition problem when it turned out to be fuel, and vice versa.
is there a chance that the timer is covered in epoxy from the stator? or is this one of the models they did away with the stators being covered in epoxy?
The socket is a 1 5/16" give me the part number off the timerbase and I will send you one
or two or12... It is hot out and was thinking it could be the ignition switch heading south?The socket is a 1 5/16" give me the part number off the timerbase and I will send you one
need your full name and address
