Matts94z28
Matt it's not as hard as it seems. Here's what we did on the checkmate re core: First we removed the floor, stringers, knees and motor mounts(inboard hull). Next we grind all the body filler from the hull (7" grinder w/36 grit), the factory using this stuff for bonding stringers, floor etc. Then once we identified the core rot used a 4 1/2" angle grinder to score the core.
Next we used wide wood chisels to start removing the core then a reciprocating with a scraper blade to remove the rest quickly. Once you're done wipe the hull down with acetone, then lay down a layer of 1.5 oz CSM mat resin that in. While that's wet lay your core in (cut and fit prior) once dry fill in any gaps with cabosil.
Now here's where you going to add strength to the hull: in this order you will put down a layer of 1.5 oz csm, then a layer of woven roven, and two layers of 1.5 oz csm. Remember each layer is wetted out completely and don't stop until you're done, also have this pieces cut and overlapping each other.
That does put it in perspective. I am excited for a rock solid hull. Pictures like this are what intimidate me lol.
Just a thought, I think I would remove the motor and cradle the hull before I removed the floor. You don't want her to get out of shape.
Got the motor de-rigged, just need to unbolt it and cut cut cut.
