Hey Jupiter, What prop are you running now? 3 or 4 blade? boatman
i was wondering that 2 , but you said @ end of vid you got it trimmed out better , so did the rpm's come up ?Did you mean 5500 to 5600rpm's? boatman
With 1.62's I need around 6000rpm to break the 80mph mark with a 26P Trophy Plus. Something is wrong there.
No offense, but why not just get a GPS and be done with it.
Jupiter, My 2100 with 225efi, 1.75 gears ran 74@ 5500 with a 27" Trophy+. You may still have a tach problem. What about the 1.62 gears? Where did they come from? 4500rpm's with 1.62's is 69.9mph before slip, -10%= around 63mph. boatman
Jupiter
I punched in those numbers on Bam's site. It does give a theoretical speed of 73. That speed would not include slip etc. In a best case scenario I've seen for a Pulsare is 6-7% slip calculation. This is a very ideal situation backed with accurrate tach and GPS numbers. If you drop in 6% slip it comes up with an actual speed of 69.
http://www.go-fast.com/Prop_Slip_Calculator.htm
I still think something is a miss with your tach. 4600 is way low. I would think you'd want to turn that motor to upper 5K. or if you do have 1.62's I'd drop down in prop to reach that rpm goal.
Good Luck
