I'm going to hopefully run the boat again (by myself) on wednesday with my GPS and check my tach..maybe my eyesite is getting old and it said 5600 rpm instead of 4600 rpm??? Maybe I have 1.75 gears???...I just assumed the 1.62 gear ratio was standard. It may make more sense because if I input into the prop slip speed calculator 1.75 ration/26+1=27 pitch/5600rpm=82 mph theoretical speed X 8% slip = 75 MPH which is what the Livorsi speedometer shows....
I think you're onto something ! I'll bet on the 1.75 and 5600. Keep us posted. Everyone's all over this like flies to ***** !
Are you sure you don't have the Skater Limited Edition Pulsare ?![]()
claupie,
I think boatman has hit it pretty close. I know Rayz here has a 2100BR with a 250 with 1.75 lower. I drove it last summer. I think he was very close to 80+-. He did not have a GPS. We were going by rpms and prop pitch. I know he was looking at running a labbed Trophy 27 this summer. I'm not sure where you are with rpms but hotdaddy27 runs his 26 with 1.62 and close to 6000 is into the low 80's. You are still conservative on setback and propshaft height. Low water pickup ? water pressure at WOT ?
On a serious note, didn't JP take a bunch of weight off of his hull when he did the resto???
If so, how much?
That may help ad a few MPH as well.
Skater Edition..................![]()
Hum ,very intersting thread,i'm learning here !!
Curious!! If i go to 15 in set back and 1 1/4 in below pad w/27 pitch,what would i gain mph...
My lower unit has low water pick-up and is a torquemaster,and is hydro lift recommended ??
It's an education for all of us when it comes to setup!! I've been doing this a long time and I'm still learning....the funny thing is that I never thought to check my tach setting in the back when we installed my Livorsi gages...I assumed it was set correctly when ordered and could not figure why it was showing 6900 rpm on a 3.0 liter motor. It was set to 4 stroke motor configuration...I had to turn the dial with a screwdriver to the 12 pole position...which shoud be correct unless someone tells me otherwise!!
Jup,
Any luck with running the boat(Black Voodoo Magic Skater Limited Edition Pulsare) today ? Give us some new numbers to b!tch about !![]()
boatmanJup,
Is that the 97' or 98' black voodoo magic limited skater air jordan Pulsare?![]()
Actually it's a 1995 Pulsare..looks pretty good for a 14 year old boat!! eh??Jup,
We shouldn't be bust'n your ball$. We got trailer queens for another month. We don't even know if ours run yet ! Keep runn'n and post'n numbers it only helps everyone.![]()
