Ramifications
Thanks, Droptop
Debating going 100% resto back to original, or maybe make some changes.
The gray and light blue stripe inlaid in the gel are pretty thin, so I need to at least do some paint work on the gray areas. My old Exiter had the same blue hull, except the Exciter had silver metalflake in the light blue/gray area. Maybe do the gray in metal flake, like the exciter, or just give it an updated look, and respray the whole thing and add graphics...not sure. I have a soft spot for the 80's Checkmate look, and for a nice metal flake scheme, although I've never seen a Enforcer/Convicor with metalflake
Boat actually has a little bit of history. Was Inland Marines, in RI, 1st Convincor. They were one of the kickoff Yamaha dealers in 84, so they put the biggest Yamaha's available on it, and used it as their demo boat for 2 years. Took it to Boston, and RI boat shows a couple times. All the guys there remember the boat, and can rattle off all sorts of facts and figures, as well as everyone who has owned it.
While I don't exactly remember the boat, when I saw it for sale, it seemed familiar. I grow up in RI, about 10 min from Inland Marine, and bought my 1st boat from them in '85/86, so I must have at least checked it out back then
Hopefully found why the starboard engine was making wasn't making as much power as the port. The TPS on both engines were way off. TPS on these old Yamis is one of two primary sensors that controls timing. Got them dead nuts matched at idle, and WOT, synced them, and adjusted rigging and to keep them as close as I could thru the full range. Hope to get out this weekend to see if that did it for the engines
The lower unit I though I had found was the wrong ratio, so still looking for a 1.85/1 RH lower.
BTW - I had an Exciter with the same color scheme
