supergenius74
Ok here it is, i spent the last 3 days doing what everyone suggested I do. I removed the front wall and flotation foam from my 88 starflite. I like others seemed to be too nose heavy, I tried adding setback and it helped but not enough and I am still having to use to much trim to get the bow to lift and loosen up. On monday I crawled up into the nose and started pushing on the front wall and it felt soft, then I drilled a small hole in it and what came out on the drill bit was wet foam so I decided it need done. With clawhammer in hand I began ripping out the wall and it came out surprisingly easy. Here is a picture after i began removing it.
![1.jpg](http://supergenius74.kicks-ass.net/pictures/1.jpg)
