The problem with having my new Pulsare 2400 is that I've been too busy boating and neglecting my 2800! Today I finally picked up my left hand CLE gearcase and new battery cables for both motors. I need to get motivated to rip the old steering out of the boat and replaced with the UFLEX steering. It's been way overdue as I started this in may...but got sidetracked by the yellow Starflite and now the Pulsare 2400. Time to focus on my twin engine beast again!
I don't know how you and some others find the time to look after multiple boats? I switched from I/O power partly because winterizing and maintaining a new O/B would be much simpler, and it is. But at the end of this past season I still checked on getting someone to winterize it for me as I was running out of time. In the end I did it myself because I figured I could do it in the same time it would take to bring it to and pick it up from a shop. On vacation I find all kinds of time to wax and maintain the boat, but the rest of the year, not so much.
Really like how this one is turning out. I'd say good luck with it, but it really is about work not luck and this ones getting the work, so you be enjoying her again soon.
I think I even got a woody!!!
Hopefully I'll get the new steering rams on next weekend!
, I fired up the port 2.5 for the 1st time!! Both motors are now running!
All I have left to do is mount my CLE gear cases and chopper props and my 2800 is back on the water!!!So close and yet so far..steering is bled, gear cases and props are on. Having a water pressure issue on the counter rotating gearcase. It won't pump water from the nose cone flush..only when it's completely submerged. Yes, water pump is brand new and has been rechecked twice along with the water pickup tube.Gonna remove the windows on the CLE case and order new O rings and check for blockage..
Nothing wrong with good ole carburetors.
