Going to a 4 blade prop with more diameter and pitch is going to be the ticket. It's may a few different props trials to get it right but I think some Bravo One 28's would probably do the trick. I think the 30's will be too big but I'm going to try them anyway.
I tried 26" Bravo 1's on my Fla Sonic, after reading the raves about them.
What a PIA.
Started w/a great deal on a pair of virgin wheels but didnt realize they had no vent holes. Boat would barely plane!
Added holes and cured that.
Then took full up trim to carry the bow and it hopped while doing so.
Cut 70% of the lip at rear of hub and cured 90% of that.
They were still several off a pair of stock 26" Rakers (similar to Mirages) and were way too much everywhere else.
Was told the Bravos are bigger than advertised.
Would have liked to try a pair of 24's.
I just played w/your #'s in the prop calculator and agree with droptop.
Using your #'s (erroring to the good), @ 5800 and changing nothing but your slip to 9% you p/u 7 - 8 MPH, or 74 MPH and 77 @ 6K!
My Fla Sonic never ran like my Ohio Sonic, dont know why but the Ohio boat was my benchmark.
Of all the boats Ive re-rigged, repowered, none ran like that boat.
W/26" Choppers @ 6400 and 9% ship, that boat ran 80 GPS and 78/79 w/26" Rakers.
I called Hoss propeller to order a set of their Hyperdrive (Chopper) wheels.
They asked my #'s and could hear them working a calculator on their side.
Got back on phone and said thanks for thinking of them but had nothing to improve what I already had.
!0% slip has always been my target and thats harder to hit than most know.
Everything I tried after the fact, slowed it down.
So that was the one and only boat that I nailed from the start.
I experimented w/set back, height, prop rotation, nose cones, toe in/out tons of props etc.
Nothing improved the orig #'s.
Also proved 90% of legend, wrong.
Not knowing your set up, Id look at engine height.
A mistake I see a lot of people making on heavier boats is raising the motors too high.
Just read a great article describing that.
Heavier the rig, deeper the wheels must be to get bite to carry the weight.
We tested that on the Ohio Sonic. Had a buddy crew for me and we went up 1/2" at a time on its manual plates.
First 1" did nothing. Third 1/2" raised RPM's w/no change to speed, thereby increasing slip.
Raised them a fourth 1/2" and the RPMs raised again, this time scrubbing speed.
Also went from neutral trim carrying the bow to requiring full up trim.
1/2 a day at the ramp poved we were there when we go there.
Your boat should fly w/Choppers.
