 The only thing I got accomplished yesterday was through bolting and mounting my trim pump slide brackets and I swapped out all the motor mounting hardware for brand new stainless bolts, AN washers & locknuts..one of the old bolts had to hack sawed off because the lock nut jammed..space under the Gil bracket was tight and I was on my back for two hours with a hack saw!!!!
  The only thing I got accomplished yesterday was through bolting and mounting my trim pump slide brackets and I swapped out all the motor mounting hardware for brand new stainless bolts, AN washers & locknuts..one of the old bolts had to hack sawed off because the lock nut jammed..space under the Gil bracket was tight and I was on my back for two hours with a hack saw!!!! That sucked!! Oh well...tomorrows another day..I hope it stays dry so I can get some work accomplished!!
 That sucked!! Oh well...tomorrows another day..I hope it stays dry so I can get some work accomplished!! ...found out the the trim pump fittings are slightly different when swapping the old style pumps to the newer style pumps and trying to connect the hoses....not to mention that the two newer style pumps I acquired are also slightly different..one has nipples inside the openings where you insert the fittings, the other does not???
...found out the the trim pump fittings are slightly different when swapping the old style pumps to the newer style pumps and trying to connect the hoses....not to mention that the two newer style pumps I acquired are also slightly different..one has nipples inside the openings where you insert the fittings, the other does not??? Moved on to other projects...changed the gear oil in each lower, reattached the transom mounted sender for the depth finder, flipped one of my slide brackets due to the threads being stripped that lock down the trim pump
 Moved on to other projects...changed the gear oil in each lower, reattached the transom mounted sender for the depth finder, flipped one of my slide brackets due to the threads being stripped that lock down the trim pump ! (again reaching my arms into impossible positions and squeezing into tight spaces)..I'm getting way to old for this!
What happend to the days when the neighborhood kid would show up interested in boats,cars ect.And would be more than happy to lend a hand!I know i used too!oh ya they didnt have computers and computer games back then!Another frustrating day...found out the the trim pump fittings are slightly different when swapping the old style pumps to the newer style pumps and trying to connect the hoses....not to mention that the two newer style pumps I acquired are also slightly different..one has nipples inside the openings where you insert the fittings, the other does not???
Now this is a useful post. Glad to see someone pointing out the things that can be encountered when doing these kind of jobs. Gives the complete story of working on a boat, not just the sugar-coated parts.
 I did get motivated enough yesterday to change the lower unit gear lube with some Merc High Performance gear Lube!! One less item crossed off my list!!
 I did get motivated enough yesterday to change the lower unit gear lube with some Merc High Performance gear Lube!! One less item crossed off my list!! . They should arrive the end of the week!!
 ! I finally pulled the starboard powerhead to replace the studs with longer studs and installed all new stainless steel nuts and washers. I also needed to pull the powerhead to install the bungee hardware for the new motor cowls (they are very close at 18" centers) and installed both new 260 style motor cowls. My trim pumps are now wired up and installed. I also had the tops of my Eddie Marine battery boxes stripped, sprayed red and ceramic coated
! I finally pulled the starboard powerhead to replace the studs with longer studs and installed all new stainless steel nuts and washers. I also needed to pull the powerhead to install the bungee hardware for the new motor cowls (they are very close at 18" centers) and installed both new 260 style motor cowls. My trim pumps are now wired up and installed. I also had the tops of my Eddie Marine battery boxes stripped, sprayed red and ceramic coated ! The list is getting shorter....here's whats left:
I have been following this thread. Looking forward to seeing the on the water pics! I love that hull, makes me want the old 251 I had! Have fun with it, a keeper for sure!Just a quick update: with the help of my buddies forklift I got the hardest work done yesterday after a long hiatus! I finally pulled the starboard powerhead to replace the studs with longer studs and installed all new stainless steel nuts and washers. I also needed to pull the powerhead to install the bungee hardware for the new motor cowls (they are very close at 18" centers) and installed both new 260 style motor cowls. My trim pumps are now wired up and installed. I also had the tops of my Eddie Marine battery boxes stripped, sprayed red and ceramic coated
1) run power to the trim pumps
2) fill and bleed the trim pumps
3) run new fuel lines to the motors
4) mount fuel pump on starboard motor
5) fill and bleed the hyd. steering
6) replace the starboard water pump and impellor
7) attach the shift cables, throttle cables, motor harnesses, etc. to each powerhead.
8) install batterys
It looks like I'm down to 1 more day of work before the beast will see life for the first time in years!!!
Holly Signature!!!!
