redstrat
I got the seats finished up in past couple of days. This pic shows how I put the panels together by gluing the vinyl to 1/2" foam that's backed with a light fabric (headliner foam). Then I stitched everything together. The trick is keeping everything aligned as you go. The 1/2" foam keeps everything plump and smooth when it's all put together.
This pic shows how I foamed the back seat frames.
I just wanted to show all the foam for these seats came out of a couch that I tore apart before throwing it away. Foam is expensive and some older foam is better than you can buy new now. I covered all the plywood parts with epoxy.
Here is the end result. The two in the middle are the ones I made from scratch.
They look great! Do you want to make some cushions for my benches?
