Alright, lets try this again.
She is running and ready to go. Tomorrow I will splash her and take a test ride
When I first ran the engine, I had slightly high water pressure, so I called the engine builder. He said it should be ok so go ahead and do a water test and take it easy to see if it clears up. (that was Friday night) Saturday morning I got a call from him saying after thinking about it, he would rather me check a few things. Well, one thing led to another and before I knew it I had the whole engine apart again looking for some kind of blockage. Long story short, I dismantled and rebuilt the engine three times before finding the problem. Dismantled, rebuilt and test ran (I mean power head off, lower unit off, mid section off, adapter and exhaust plates out) three times since yesterday. Each time I was looking for something different but found nothing. Turns out it was a faulty poppet valve. I found this out on a hunch and by reaching up under the power head and trying to move it by hand. It was locked in place, so I swapped it out with an extra I had and presto! Perfect water pressure
Frustrated I went through all of the work I did, but glad it is fixed and a simple one at that. I will post pics from the water test tomorrow
Here is a cell phone pic from today.
Those seats from wildman match perfect with the color combo!!Your boat turned out really well!!
First off, boat looks GREAT! What a nice job all the way through and it paid off with the end product for sure!
I was wondering about your water pressure numbers, what were they and what did you have before?
My motor has always had 'higher' water pressure numbers then most other's report, and when I put a new water pump in it this spring, its now a few lbs higher then it was last year across the board. Seems to cool just fine, has good tell tale, etc. Reason I ask, is because we have virtually the same motor...
Must be flexing pretty good for the cracks to surface like that. The only thought is that you reinforced the corners only to have flexing in a different area. I would watch it over the summer then go lipless during the winter.
