I've got the same one in the picture works great! Takes a 9/16" wrench to tighten/loosen the plug.
I suppose I stand correctedWhat made you go that route, just the bling factor or is there something I'm missing?
When I did mine i lined the hole with 5200 and put some on the flange then screwed it in. worked great.
Forgot ask this question last night. Gas tank is going in this weekend with no foam. What should I install under it so it does not rub on hull/fiberglass? Was thinking rubber seal that goes under garage door with 2 inches cut in middle to allow water to drain if needed. Tank will be bolted to stringers. Thanks for help again.
Eric
I'm enjoying watching your resto come together.
