bdusted440
Well it floats runs and moves.And LOOK MA NO LEEKS.
OC gel will not spray as smooth as other paint it has to be sanded. It is not realy paint it is resin, its not realy designed to be sprayed like that, it was meant to be used inside of a mold. It also cures it does not dry. And in order to trick it into cureing outside of a mold you have to add surfaceing agent. This is parafin wax disolved into styrene monomer. Then as the styrene evaporates from the surface of the sprayed gelcoat it leaves behind the wax and it forms a layer over the gel. This the is removed by sanding and buffing.Originally posted by orangecrush:
What Happened ???? they having trouble with there shooter you shouldnt be sanding if they sprayed it.
