Convincor LS Swap Project Thread
Cant wait til you get it all worked out Corey. Its sure is one bad machine and sounds amazing at the lake. Maybe Ull see you down to Millets soon. I need to get my motor down there and get the plan rollin ! It will all be worth it when you get to mash that stick and hear the motor pullin hard echoing across Cumberland !
Sorry to hear about all of the setbacks Corey, I'm also really looking foreward to seeing/hearing it one day. And thanks for being the test mule for all of your R&D for such a cool swap. LS took over the automotive scene quite a while ago, it's about time they take over for these BBC. The 502 in mine is a ton of fun, but it's so damn heavy in such a little boat.
Yeah, the power they make in such a light weight package is really impressive.
However, I'm contemplating adding a little bit more weight.......:
I'm pretty sure I have some kind of sickness
It's hardly a sickness. I'd think you were sick if you never considered twin turbos. LS motors love boost, especially turbos. Everyone I know of that has swapped a LS into something locally, has it boosted via turbo. From mild to wild, they'll hang on tight and keep kickin'!
I stumbled upon this website, seems to have a pretty good list of parts and options for a swap available. http://www.chelseacoachworks.com/pa...ww.chelseacoachworks.com/boats/pages/ls1.html
are you running the steam crossovers on the heads ?
I was running stock one that came on the motor at first. Since it came out of a TBSS, it was just the front two ports. When I started having temp issues I switched it to the Trick Flow 4 corner set up. So its all -4AN stuff now and I have it exiting into the hose that goes from my header to the thru-hull fitting that dump out of the transom. That way its all uphill and any steam can exit.
Ls motors are great. I put a LQ4 402 stroker in my 223 maxxum 3 or 4 years back it worked great once I learned EFI tuning. My current project is an 04 300 convincor. Its getting 2 Procharged 6L motors. Love this build. Ls3 motors are wicked.
Make a new thread and show us this 300 project. Sounds sweet.
Now that is freaking cool!!!! After doing this build, (well, I'm still doing this build, lol) it has made me want a small twin engine boat like a 300 Convincor, 32 Sunsation or 29-32 Fountain and do the swap. Two aluminum motors will weigh the same as a single big block, and 1200hp would push that thing pretty dag gone good!!!
Just wanted update this thread so nobody would think I forgot about y'all. My Thanksgiving/Christmas season was ridiculously busy so I just filled the motor with anti-freeze and let it set in the garage. I recently took the motor to my engine builder so we could go through it and see what we could find. To my surprise, both head gaskets looked great. The only thing we found was something must have gotten sucked in to cylinder #8, I'm guessing due to the reversion and scored the block a little. Also, we found a TON of corrosion in the block for such a small amount of runtime. Here is a pic of what I found when I pulled the crossover off the front of the motor, and this is after only 3-4 hours of run time.
I'm thinking that part of the corrosion issue is due to the fact that I'm not running a Merc-A-Thode on the engine and with all the electronics on the motor, there might be a small electrical leak somewhere. So needless to say, the Merc-A-Thode is going back on the motor next year. Also, since the block is scored, instead of trying to bore it again and replace all the pistons, I think I am just going to replace one piston and replace the block with an iron one. Honestly, all that corrosion scared me a little. The iron block weighs about 96lbs more than the aluminum block, and in the grand scheme of things, I think that might help the boat balance out a little bit better. Plus there is a little bit of added strength with the iron block.
So, the question I have now is why did the engine run hot? The only answer I can come up with is that my cooling system design must have a flaw that I can't see. So, that being said, I am throwing in the towel on it and breaking down and buying this set up from Hardin Marine
http://www.hardin-marine.com/p-7408...s6-serpentine-pulley-accessory-drive-kit.aspx
I will be going with the full closed cooling set up. It's pricey, but it looks pretty damn good, it works, and it comes pre assembled so it bolts on in less than 30 minutes. Also, not having to winterize will be awesome!! Just drain a couple things and go. And honestly, at this point I'm over trying to figure this sch!t out. I just want to enjoy my boat and put some quality hours on it, so this will be worth every penny!!!
One of the many goofball ideas that I had on this project that actually worked out really well was my electric/hydraulic power steering system. I ended up using an electric power steering pump off a 2000-2005 Toyota MR2. I wired it to a switch on the dash with a relay under the rear seat and it worked awesome!!! I mounted the pump on the floor in the bilge behind the back seat and built hoses to run to the rack.
It took awhile to bleed the system, but once I did, the steering was great. The pump is also surprisingly quiet for being a 50amp motor. You couldn't really hear it at all, especially when I had the Aeromotive A100 fuel pump running. Its a shame that my new accessory drive will go back to a pump that is driven by the motor because I read somewhere that turning the power steering pump is the biggest power drain on an engine. But, now that I know that it works, this can be utilized on any boat, no matter what the power.
I'll update this again as the motor goes back together and I get the new cooling system all bolted on and the motor back in the boat.
Hoping for a great upcoming season and many more Corey. Cant wait to run the lake along side ya and get a nice vid all aired out ! I would like an electric water pump but not sure they exist in marine form. Never looked into it. See ya soon.
Thank man, me too!!! After last summer, I just want to start using the boat again. I am also the type of person that once I have a doubt about something, its always in the back of my head and I now have huge doubts about my cooling system. I am pretty sure that I could build my own closed cooling system using stock style stuff and custom brackets, but at this point, its just easier to buy this set up, bolt on and go!! Plus I really like the way it looks. And, I got off the whole "budget build" bus about two weeks into the project, so screw it!!! LOL
Is that boat named "LS Money Killer"? Damn son!
Tell me about it!!! The only saving grace is that I pretty much stole the boat 4 years ago, and somehow, the wife still thinks I only have $4-5k in the build....:rof:
anytime using aluminum heads/block etc, need closed cooling, even in mostly fresh water corrodes bad pretty quick
Sad to see your crossover setup didn't end up working out, i can't wait to see your closed cooling setup on there though. Through your trial and error I guess that's the route that I'll be going also.
