Chris E
Yes, fill any low spots. And if your going to paint anyway, then definately secure the transom with screws from the outside, just run them through a peice of wood first then into the glass and into your transom.
1. Have several wood blocks ready with screws already in place, then you can just hold them up to the transom and hit them with the screw gun.
2. Make sure you predrill the fiberglass so that the screws go right into the transom. Your going to fill these holes anyway. The idea is your squeezing the fiberglass layer between the wood.
This method is way cheaper than investing in hundreds of dollars worth of c clamps in various sizes. That you may only use on this boat.
i'd better only do this once!!!!! although a starliner could be fun
your getting there
just kidding Gus - couldn't leave that alone (believe me i tried)
