Robbie, how many cases did YF charge you for his services?
No cases, just gave free room and meals!!!!
So here we go again!!! I got all of the Interlux paint and primer sanded off the boat yesterday. Today with Brians (YF) help we got the boat taped up, blown down, wipe off. Then let YF worked his magic with the spray gun!!! YF primed the boat and added a guide coat for sanding. For you guys following we used dupont products this time. The first few pictures are of us horsing around, you gotta have red hand prints on the a$$!!! Then actual pictures of the boat.![]()
so, your using auto paint?...do you think this will hold up especially on the bottom?..im thinking if im going to paint mine, nows the time to flip it, since its just a empty shell right now....I dont want to do this twice...already have too much into it....so auto paint would be doable for me...
ballardnboyz, when you think about it, a boat is no different than a vette. As long as it does not stay in the water, you can use automotive paint. The issue lies in the fact paints are breathable. When it is under water for extended periods, water will be absorbed. This creates small "pimples" filled with water. Noce that starts happening, you will have a mess. The other side is it might take 5-10 years before that happens unless its in the water 24-7.
well my girl is trailered at all times...other than when were rippin around...so no worries there...How about the Interlux vc epoxy paint, would that hold better in the water?...I really only want to do the bottom once, right now i can flip it and go....and if i use the interlux for the bottom and auto for the top, will i be able to match the colors?....how much do you charge to spray a prepped boat?![]()
If you're gonna leave the boat in the water for a few days then yes the Interlux VC epoxy will be the better choice. http://www.jamestowndistributors.co...=2330&familyName=Interlux+VC+Underwater+Epoxy. However your choice of colors are white, white and white, so you can match the sides and top!!!![]()
wait ...so interlux only comes in white?![]()
I didn't take any pictures, however if you need to see I'll snap some tomorrow.![]()
Now what kind of question is that?![]()
Hey guy a little late to this thread but ..............what primer did you use and what paint are you going to use .
