timapexcomputer
Hey all Tim here.
I have an MX16 with a 1980 Evinrude 115 hp - E115TLCSA. Just did a new head because of a bad plug hold that was beyond repair. Also did carb kits and impeller.
Motor is running very, very well. So we go out, take a good run at 45-50mph GPS on a little 17p prop. Respectable in my eyes.
Anyway, after about 15 minutes it stops running good. Once hot I assume. It still goes but like it is an 80 HP instead of a 115. No sound difference but much lower RPM. Takes longer to plane too.
I feel like it is down a cylinder when hot.
So a bad coil is my assumption. Here is my question:
What would you do to figure out if it is a bad coil, and which one? Each of the 4cyl's has its own coil and because it only does it when hot, the plugs all read the same.
Thoughts? Any help is much appreciated. Cheers, Tim
