OFFSHORE GINGER
Banned
just curious what forum was that on ..............Here's a couple of pictures I found from another forum that shows how a transom, stringers and the floor goes together.
Jeff why buy two different types of fabric because my next question depends on your next answer and that is ......have you decide on what resin you are going to use Epoxy , Vinyl , or Poly ? Jeff , the bottom line is ......i would never use matt for any transom repair considering you need to take load conditions , and the the pounding a transom takes with an O/B into consideration .......or should i say show me the beef .
Hey guy , first off the PL is called a fillet and second laying 1708 over a stringer that has rounded edges is a piece of cake , and yes i would only use one type of fabric when doing a transom which usally is 17 oz considering i only use Epoxy in all of my repairs , and when i worked at Skater i did all the custom fabrication of the transom and motor well's for trip O/B along with adding X-tra knees for every application .
There isn't much you can do to save it unfortuantely. The best way to replace the transom is to pop the cap slide it forward a couple of feet. Then you've got full access to replace the transom.
is there a easier way to remove the rivets...with the pin in the center, the drill bit kicks to the side, what a pain in the a**
Try a punch to knock the middle out then drill the rivet.
thats what i was thinkin....did you read the post above about the order of resto?? what are your thoughts, I would hate to peice the floor. However i understand what he is saying....I have a different hull style, that is my stringers dont attach to the transom, just the knee support, so I dont see how anything will change on the sides of the hull??? plus my knee support attach to the hull not to the stringers. Im thinking transom/knee brackets...reinstall the top then the core, stringer and floor....am i off base??
Drop has valid points, however you aren't removing the top completely just sliding forward enough to replace the transom.
I was actually thinking of removing it, as it needs some help under the bow...see my post "butt dents"....Maybe i can just put supports side to side to the correct dimension to hold it in place? However the repair needed could be done while the top is on...![]()
Take a look JT Protronis resto he removed the top completely. You can remove the top then add 2x4's notched each side to hold the hull shape before replacing the floor.
Good man ............Epoxy is so much easier to work with then Poly or Vinyl providing more tensile strength ,longer work time & pot life / depending on what hardner you decide to use Fast , Slow , or X-tra slow , along with no stank ............. and yes two layers of 3/4 marine grade ply .ill be using epoxy...I have a good friend who has been building/shaping surf boards(remember i live on the ocean)for 35 years, hes a wiz with glass, so i think that will go smooth. The process seems straight forward, just want to be sure im using the correct materials....so two layers of 3/4 marine plywood depending upon my existing transom??
Ha Ha Ha Ha i forgot to answer this post and thank you . Well back to work .......Hey OG, your a jet mate on this site now!!! your movin up the ladder fast old boy!!![]()
