Oops, I was wrong on the compression. Now for punishment, I have to list Per my Mercury service manual:
All models, using a fully charged battery, throttle shutters wide open and cylinder block warm: 105/140 Jet/135/150/XR6/MagIII/175/200/XRI/Promax 110-135 psi. Variance between cylinders should not exceed 15 psi. So you're good to go!
I agree with everyone else, your impellor looks TERRIBLE. Try changing that out first before you change the whole pump assembly. One thing you can try to check for blockage: Pull the T-stat and run a pressure hose up your midsection into the water tube and see if you get flow out of the block. Or, push water backwards down the block and out the water tube. I had to do that with a motor last summer that was all clogged to heck.
Oh and did I mention Mercury Motors aren't that bad
