For squits and giggles you should try a old 24p Mach I Sterndriver. I have tried a couple now and are my favorite prop on my 253 as far as handling. aired out perfectely, no chine walk, and balances nice on the pad. No bow steer when crossing wakes or setting the boat back down in the water.As I have had an entire season to run my new girl I have also had the opportunity to test several different props. There seems to be a few new faces here with new 2400LD's or 24BRX's so this info may be of some help.
All speeds are GPS. Gear ratio 1.75 w/6" setback. All props tested with PVS system had holes plugged. All testing done with full tank of fuel minimal gear and driver only aboard.
The baseline was the 23p Tempest plus 73.5 @ 6500rpm - 2.5" below pad @ 9% slip. - Hole shot was terrible easy to blowout, midrange was anemic.
24p Bravo1 Labbed by Bblades (23.3 actual pitch) 71mph @ 6250rpm - 2.5" below pad @ 10% slip.
Great holeshot & midrange, top end suffered a bit. Will be converting to FS style.
24p Rev4 72mph @ 6250rpm - 3.25" below pad @ 11% slip.
Terrible hole shot easy to blowout, midrange was just ok top end was a bit better than the bravo.
23p Enertia ECO 70mph @ 6150rpm 3.25" below pad @ 9% slip.
Ok hole shot decent midrange, due to the large 16" dia. it did a good job of keeping the boat on top of the chop unlike the 23 tempest I tested.
24p Bravo FS (23.3 actual pitch) 72.5mph @ 6450rpm 2" below pad @ 11% slip. Excellent holeshot, midrange has great punch, overall ride quality best out of any prop tested. Seems to keep boat on top of chop very well with top end closest to the baseline tempest.
Thanks for sharing the prop testing.
I'm still using the 23p Tempest Plus 71mph @ 6400rpm and looking for another good prop for the reasons you mentioned.
I will keep a look out for the 24p Bravo FS or even the 24p Mach I.![]()
Sounds like a good performing prop from what I can find for info. The propensity for losing blades is troubling though. It also seems like not many will work on them because of the welded blade design.
Also keep in mind my setup doesn't require a lot of stern lift as in a i/o application, one reason the diffuser ring is much shorter on the Bravo FS is to limit stern lift and reduce drag.
My 253 hates stern lift. My short barrel props are the best handling ones. My long barrel rev4 and bravo I handled like poo.
Rev 4 is too small of a dia for your HP I would think, I was able to break the one I tested loose at half throttle. When I get the std Bravo back from being converted to a FS you are welcome to try it.
That's a good price and I'm assuming I could use my existing hub kit from the 23p Tempest Plus. I think I may get it!Teague has the FS for $595 free shipping.
I may have to take you up on that! Naw, rev 4 doesnt blow out with as big as those ears are. The even smaller 14.5" machs hook up very well and i got 15% slip which i dont really get better than that. I think my nose coned drive allows the smaller dia to bite well. Loads the inner blades parts heavily. I actually want to try a mazco re4 chopper for kicks. Anything 3 bladed i blow out instantly. Even 27p mirage plus. Mine seems to have fairly high x dim.
jjg, for the free shipping, did you have to enter a coupon code. The Teague custom marine web site was charging $44 for shipping when I was going to check out.
That sure is a lot of motor!![]()
