bigredinohio
I am sure Mike will like the plug, plus he is great to work with
I would use the interlux over imron anyday. Its a lot safer and easy as can be to use. I used their product on my hull (different from what rob used) and it was so easy, it would be hard to screw up. Thanks for sharing Rob. I do have a good buffer, but I need help putting the stroker motor in the enchanter ....... you did say you wanted to learn about I/O's right![]()
My knowledge in I/O's (or motors in general) is limited but I'm willing to help you out in any way I can.
Sounds like Interlux is the way to go.
